Configure a platform VLAN and associate the Fail Open I-SID.
Use this procedure to configure Fail Open I-SID. If the switch declares the RADIUS servers unreachable, then all new devices gain access into the configured Fail Open I-SID. 0 indicates that Fail Open I-SID is not enabled for this port.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure Fail Open I-SID:
    eapol fail-open-isid <0-16000000>
Configure the Fail Open I-SID.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config-if)#interface gigabitEthernet 1/10
Switch:1(config-if)#eapol fail-open-isid 1000
The following table defines parameters for the eapol fail-open-isid command.
Variable
Value
<0-16000000>
Specifies the Fail Open I-SID value.
